Here's the photo step by step . . . It is NOT necessary to remove the control unit from the center stack . . .
Remove the ***** by pulling them straight outward (you may also need the gentle assist of a small prying tool as shown) . . .
The bulbs are under little white plastic flaps . . . 9:00 o'clock position left side and 3:00 o'clock position right side . . . note that my right side flap has broken off . . .
Turn the shafts to rotate that black part out of the way . . . Screwdriver is pointing to the left side flap . . .
Unfortunately, the plastic gets brittle with age and I broke the right side flap off when I pried it up . . . Note the bulb socket showing on the right side . . .
Use an appropriate size soda straw to slip over the bulb and wiggle / pull it out . . .
The bulb is a miniature wedge base bulb that has a green silicone cap on it. This is the bulb
https://www.fcpeuro.com/products/mer...-072601-012230
Found them here too . . . a bit less expensive . . .
http://www.allbatterysalesandservice...fm/4,1107.html
Now I need to find the little silicone caps (because I damaged mine) . . .
