amx1397
I got a set from Needswings about 2 1/2 years ago, AND NEVER HAD TUBES IN THEM they were fine ,, you should have BIAS in the front also, the ET street radial you can run your stock tires. I now have DR's on 16" rims.
these also use the stock type lug bolt (ball type) after market wheels lugs use tapered , these rims are 8.5 x 16 with a offset of 20. the tire u use should be 26" tall jim
yes, my tires are 26" tall. I found the same 16" early 90's SL wheels that rob sells on ebay from a local seller for $100. Granite they are prob not as good condition as the ones that rob sells, butni plan on getting them powder coated gloss black anyway. Its my understanding that the radials u suggested (bias ply) are strickly for the track. The ET streets im talking im talking about that i bought (#3793) can be driven on the street as well for up to 15,000 miles. Not goin for a "this is better than that" topic, just saying one set is more dedicated to the track, and the other set u can put on at home and drive them to the track and are a more aggressive tread pattern.
