Originally Posted by CdnXFire
I'll buy a Ferrari 348TB be for i spend that on my xfire ! my next question is what engine also uses our 6sp transmission ? building adapter plates can be a real pain in the *** i've found out from years of building off-road jeeps and drag cars. i'm looking to try and keep the cost under 15 grand an that includes new wheels so if i can find a decent MB wreck with a desirable engine its a go. i figured if i gotta put twin turbos and pull the engine to lower compression anyhow why not just swap it. I'm currently in the middle of building a 1999 35th anniversary edition. Ford mustang with a bored and stroked 351 to 427 cu in with 850 hp and 2 stage nitrous to boot.
Good Luck if you decide to do it. I'm not sure which other MB's use the 6 speed, I'm not even sure any of the US or UK V8's do. The block is basically the same as the V6 so it should mate up OK as long as the input shaft/flywheel setup is similar.
I think bolting in the V8 lump and mating it to the trans, then fabbing up the exhaust and ancillary mounts etc. is the 'easy' bit. The fun will start when you try and get the rest of the car to be happy when you pull the ECU and other modules. Even assuming you completely transplant the electrics from the V8 you may get problems with the rest of the integrated CAN systems scattered around the car. Just ask HDDP what happens when you start disconnecting things.
You could just rip the whole lot out and make up a new loom and go for a custom management system. But its all time and money. It also depends on what you are trying to achieve - a sophisticated and refined road car with a 'factory' feel, or a no compromise racer. The latter is easier, the former is very difficult indeed.
I would relish the challenge but I just don't have the time or financial resources to contemplate it. So I wish you the Best of Luck if you go ahead.
