Re: Alarm going off on its own! Interior light flickers / unlocking randomly if drivi
Well I guess I should introduce myself at this point.
Hi, I'm Herman.
So have you pulled the fuse yet? ( it is so very helpful when fixing cars over the net to have good linear descriptions) Is the car a Vert or a coupe? If its a vert no dealership will be able to open it (unless they have a tricky fellow who really wants to figure it out) you would need to print off the instructions from here, and take them in.
In fact STOP!!!!
do not take this car to a Chrysler dealer, if it's not warranty work. Even then I would wager less than 10% of those dealerships have a certified Benz mechanic employed anymore.
Pull fuse 9 / disconnect the battery for an hour / reconnect the battery and put fuse 9 back in./ unlock the car and open the trunk / pull fuse 9.
If you already pulled fuse 9 put it back in and try to unlock the trunk, and then follow the previous instructions. Disconecting the battery resets the alarm.
Have you dried out the trunk well yet? If you get the trunk open, pull the strofoam inserts and check the status of the well underneath.
Have a merry Christmas, I will check back later.
