Mrmiata
Running that setup on 2 out of 3 of my cars. You did remove the OEM filters and seal off the covers correct?
I removed the stock filters, what part of the boxes do I need to seal off? Also, do I need to put anything over the holes were the factory plastic tubes attached on either side of the radiator to keep larger debris from entering? The kit came with two brackets, did yours come with the brackets and if so did you use them? I have everything tightened down really good and everything seems very secure. Anything else I need to know if I am going to run this setup?
You are absolutely right lildaddym, she was so excited when I opened it, that's why her and the intake are keepers. Been together for 32 years and she still can surprise me from time to time.
