Old Dec 27, 2014 | 05:24 PM
  #3341 (permalink)
xjken's Avatar
xjken
Originally Posted by Mrmiata
The filter housings.. where the filters would actually make the seal when you put them back together with the 4 torx screws.. you can see in the filters where they sealed - sandwiched the boxes to the cover.
If memory serves.. a 3/8 wide door sealing foam rubber works.. Like you use for the house.
Just to be clear, I run the door sealing foam along the edge where the OEM filter would normally nestle into?
