Old Dec 31, 2014 | 06:19 AM
ala_xfire
Default Re: Headlight replaced but still won't turn on
I put in a new fuse just in case and still no go. I switched the new fuse and passenger side fuse (why? I don't know.... just another thing to hope for a miracle) and same result.
He said he already did that, 180.
Question : does the other light in this unit work ( you didn't say whether the low or high beam was out ) ?
Does the turn signal work ?
If not, then I'd suspect maybe the connector to the headlight has an issue, or it could be the ILCM ( the headlight switch unit ).
