Old Dec 31, 2014 | 09:28 AM
ala_xfire
Default Re: Central Locking and Security Alarm Issues
1. If the old pump was indeed wet and needed replacing, did you make sure all the connectors were corrosion free before connecting the replacement one ?
2. Have you tried just disconnecting the tow away module ? ( not sure what happens if you do that )
3. Did you dry out the foam packing for the pump REAL good ?
Where are you located ?
