Old Dec 31, 2014 | 09:43 AM
modernuser's Avatar
modernuser
Default Re: Central Locking and Security Alarm Issues
1. Yes, the connectors were corrosion free.
2. No, I have not disconnected the tow away module; but I'm getting the car back from the dealership today.
3.Yes, I dried out the foam as dry as the desert sun.
I live in the Mobile, Alabama area.
1. If the old pump was indeed wet and needed replacing, did you make sure all the connectors were corrosion free before connecting the replacement one ?
2. Have you tried just disconnecting the tow away module ? ( not sure what happens if you do that )
3. Did you dry out the foam packing for the pump REAL good ?
Where are you located ?
