Thread: TPS Light On
Old Jan 1, 2015 | 04:31 PM
crymar's Avatar
crymar
Default Re: TPS Light On
use a pick or other fine tipped tool and depress the top of pin 2 so it will slide out. Push the pin back into the connector in the 6th position and reinstall the connector.
Could someone provide a bit more detailed information on a previous post that described how to disable the TPS light by relocating a wire in the connector under the dome light? I dropped the dome light and found the connector, but no matter where I inserted a pin around the no. 2 wire (gray w/yellow tracer) I couldn't remove it. I'm obviously missing something. Any help would be greatly appreciated (and also relieve my aggravation.) Thanks.
