Old Jan 3, 2015 | 04:16 AM
FUBU's Avatar
FUBU
Default Re: 2 issues: Passenger side rattle / "burnt smell"
The pump fuse is the big orange one ( 40 amp ) on the RCM.
Yes, you can test it by connecting +12 to one pin and ground to the other. ( ground to the pin that had the brown wire connected to it )
Most likely a stuck relay in the RCM, sent it to DJ ( tighed1 ) and he can replace the relay for you.
Meanwhile, just remove the air pump fuse, won't hurt anything if the pump don't run, other than passing emissions tests.
Thanks for info man!
"Most likely a stuck relay in the RCM, sent it to DJ ( tighed1 ) and he can replace the relay for you." - do you simply mean I need to do re-soldering? Or do I need to change any hardware?
Ok, I'll re-solder it, see if anything is solved. Otherwise, orange fuse is out.
