Old Jan 3, 2015 | 01:16 PM
TexasSRT's Avatar
TexasSRT
Default Re: Seat Heaters in Racing Seats using Factory Switch How-To
Now that you separated the material, you can pull the material through the front. This seat had velcro holding the material in the crack making for a very easy installation. If your seats don't you will have to feed the other heater element inside the seat back like you did in the seat bottom.
This is what you will have after pulling the seat back material off. Pull the protective paper off the tape on the seat heater element and install on foam pushing the wiring through the crack between the seat bottom and the seat back.
Make sure the wire is fed the right way and re-install the hog rings.
Now push the fabric with velcro back into the cracks on each side until the seat back looks like it did before you even started
