Seat Heaters in Racing Seats using Factory Switch How-To
Jan 3, 2015 | 01:18 PM
permalink
TexasSRT
Apr 2014
51
Hampton, VA
Re: Seat Heaters in Racing Seats using Factory Switch How-To
This is what the bottom of the seat should look like with both element wiring harness'.
This is with the velcro fabric piece stuck back down.
This is with the seat sliders re-installed.
Now to the wiring, this is the factory module from the bottom of the seat. There are 3 plugs that go into this module. The 2 thick wires one red and one brown go to the seat adjustment switch, I cut those wires and taped them up. Four more wires go to the seat belt buckle, they are easy to determine by the long wire harness from the buckle to the plug. There are 4 other wires, these are the seat heater wires, 2 brown and 2 blue, brown are negative and blue are positive. The pictures above show red boxes, that is where the seat heater elements plug into.
These are the seat heater wires and plugs you need to cut from the bottom of the factory seats
Now splice those connector to the seat heater elements, remember blue is positive and brown is negative.
These pics are showing how the white and black connector snap back together and then plug into the factory module. The plug can only go in one way, it has a notch on it so don't worry about getting it in wrong.
This is a pic of the factory plug coming out of the carpet that you will plug back into the factory seat module.
TexasSRT
View Public Profile
Find all posts by TexasSRT
