Searched mystery no start... want to confirm a few things
My first post. Just bought an 04 Crossfire with a no start issue. After searching and checking the car I've ruled the out the RCM. After disconnecting and reconnecting the battery the car will start and die 3 times. I'd have to disconnect and reconnect the battery to get the vehicle to do this again... therefore I'm under the assumption that I've got a SKREEM problem. The only difference to others here is that my cluster does not work. The only lights that come on are the red battery light, airbag light, and a yellow light which i think is the exterior light fault warning. No mileage or anything else, its as if the cluster is completely disconnected. Radio comes on, although buttons are inop (unrelated I think). Blinkers and hazards don't work either, probably related to the cluster prob. My next step is the dealer unless anyone has any ideas.
