Old Jan 4, 2015 | 03:55 PM
  #44 (permalink)
syfi's Avatar
syfi
Default Re: Supercharger not working-suggestions?
Originally Posted by Sweet2002
Should the engine control relay hum when the motor is running? The black plastic housing for the ECU and the ECR has a hum coming from it. I see rock Auto sells this relay for just $127. Anyone know if that is an OEK MB part? Doesn't seem like somebody would make them besides MB but what do I know! Thanks. I know the PUMP is good and the SC clutch activates when hot wired, something in between. Mark
If you haven't done the RCM resolder yet, then send your board to tighed1 NOW. DO NOT buy a new board as it will develop the same problem as the OEM one (same bad solder used). Let tighed1 do his magic on the board you have and you'll never have to worry about it again, plus it will fix a plethora of problems associated with the board. And you really can't beat the price!
https://www.crossfireforum.org/forum...tml#post430634
