Old Jan 5, 2015 | 06:00 PM
ala_xfire
Default Re: New member/owner with problems, hello.
For the P0135 and P0155, check Fuse #2 on the RCM, or the engine control relay contacts.
For the P0410 and P0412, check the RCM air pump relay for burnt contacts.
For the P0403, remove the ECR valve and see if you can clean up the carbon deposits, otherwise replace it.
( shortcut on the RCM stuff is to remove it and send it to tighed1 along with $20 and he'll fix it up for you.
send him a PM first )
Another thing you could do is get the heck out of Atlanta and move to Alabama like I did. No inspections here
