JEFASOLD
From this point on, ur mods are gonna need supporting mods. Keep in mind that with all the increases in cfms, not only is a tune adjustment in order, but u also need to upgrade to an SL55 fuel pump, high flow fuel filter without internal regulator, and add an external regulator. Remember when i said mods will depend on other mods? Well none of the ones i just mentioned are any good without upgrading ur injectors. llol
Who told you that? If you read the threads, you would have noticed that some of us with these mods have not needed to go to bigger injectors.[/QUOTE]
I thought i remembered someone mentioning to me that oem injectors basically defeated the purpose of upgrading the fuel pump? I know that just upgrading injectors defeats the purpose without upgrading fuel system but maybe i misunderstood about needing to upgrading injectors when upgrading pump/filter.
