Old Jan 9, 2015 | 11:38 PM
arejohn's Avatar
arejohn
Default Re: Pulling to the left constantly
Unbalanced Power Assist – If you have leaks in the control valve they need to be sealed. Check this by raising the wheels with the engine still running. Off-center steering could route the hydraulic pressure to one side over the other of your boost cylinder piston. This will cause your steering to turn more to one side or the other by itself. If this is your problem, the steering gear or control valve assembly should be replaced.
