I did not think the few mods I have and am considering would require more fuel.
1. Who dyno tunes Mercedes?
2. I might just consider a Kenne-Bell boost-a-pump for additional fuel. 1lb. increase for each lb. of additional boost. It is the dyno tune that has me confused. Did Jerry do the tune over your laptop or work with the owner/operator of the dyno? What AFR's are considered good for these motors, 11.3-11.5:1?
I am running a stacked setup with SL55 pump, free flow filter and adjustable regulator set at 66 psi with a tune from Inmotion (Rob's recommendation). I talked to them about a retune and was told within the limits of my system, the ECU would make the necessary adjustments. I have a Zeitronic AFR meter and datalog setup and unless I do anything more, which I doubt, I am OK. I do have NW DCAI and manifolds also. I have a local Chrysler dealer that has a dyno ($81 for 3 pulls) and they actually know something about the Crossfire.
