Old Jan 11, 2015 | 12:52 AM
  #104 (permalink)
JesseJamessrt6's Avatar
JesseJamessrt6
Default Re: Ground Control kit reviews
It's not any lower than before, I kept just about the same ride height as the cut OEM springs I started out with. Outside looks the same, all the difference is driving and handling with no rubbing.
In my opinion these are also needed for the front camber
and something like this for the rear sway bar and upper rear control arm adjustment for camber (GC sells the very nice curved one with rubber coated end links)
This is pretty low and would get some rubbing unless using stiffer springs
This height with no rubbing using medium stiffness springs
