Diabloflash
Hello,
Check Engine - Because of CODE P0102 (Mass or Volume Airflow A)
( I just retested to make sure there was no other codes)
Any Ideas?
Umm.... k. Did you try disconnecting the MAF sensor and then running the engine? With the MAF sensor disconnected the engine will go into a sort of default AFR setting... If it runs better when the MAF is disconnected then you have your problem.
