Old Jan 16, 2015 | 11:05 PM
rmcdaniel12's Avatar
rmcdaniel12
Default Re: Anyone using these needswings mods
Originally Posted by JEFASOLD
To clear things up a bit. If you aren't running lean, there can be an advantage to the bigger injectors in that the duty cycle will be lower and thus may add some reliability in that area, without actually increasing performance. Your choice of the 178 pulley is good, with the 181 crank pulley and that SC pulley you will be exceeding the safe limits of RPM on the SC pulley bearing.
Thanks for the heads up on that. U just made my decision very easy.
