Old Jan 17, 2015 | 04:03 PM
32krazy!'s Avatar
32krazy!
Default Re: XF vs SLK suspension
no info given anywhere on spring rates from factory. i have seen am springs sort springs and limited springs and visually the only difference is amg springs are marked eibach. the # of turns the height and coil thickness are all the same
you can change the height slightly with rubber springs pads and other than that cutting or trying the new stuff coilovers are about your only options
