Old Jan 22, 2015 | 10:48 AM
tighed1's Avatar
tighed1
Default Re: Fuel pump or Fuel pump relay?
Could be the CPS. Check HERE.
Could be the actual fuel pump relay located in the RCM. Open the RCM and check to see if the contacts close when you turn the key to the On position for the Fuel Pump Relay #4 in the photo.
If not, manually close the contacts and see if the car starts. If it does the coil in the relay is most likely bad.
I and others can repair this for ya.
tighed1 at Hotmail . com
