Old Jan 27, 2015 | 02:22 PM
syfi's Avatar
syfi
Default Re: SL55 AMG V8 Intake Conversion
The way I've read it, goes as follows:
82mm Y Pipe - Part #: A 113 090 03 29
82mm Throttle Body - Part #: A 273 141 03 25
Throttle Body Gasket -Part #: A 113 141 07 80
SC Inlet Gasket - Part #: A 137 141 07 80
Read more:
F/S 82mm Throttle Body + Y-Pipe - MBWorld.org Forums
The 113 094 01 03 is for the 82mm "Y" pipe only, which is no longer sold separately anymore.
The A 113 090 03 29 is for the full 82mm assembly which includes the "Y" pipe , both hoses and clamps, and is the only way to get a new Y pipe.
I did manage to procure a used assembly from the salvage yard for around $70. Just make sure that both upper and lower tabs are present on the Y-pipe for a direct snap-on fit.
If you find one with broken tabs dicker the price down . It's still useable with a screw-clamp.
Mike S.
