Old Jan 28, 2015 | 09:16 PM
  #3393 (permalink)
Crossbow34's Avatar
Crossbow34
I finished installing my Daytime Running Lights.
I had originally put side-facing LED's on the two fog lamps.
But after seeing the LED's installed by SteveDask and SparlieSRT6 I decided to put a pair of LED's on the headlights.
The power came from a stud behind the drivers side fuse box. After I located the correct stud it was a simple matter of crimping a ring connector on a wire and run the wire forward (through an in-line fuse) and out to a three way switch (ON-OFF-ON) that I mounted in one of the extra factory supplied punched holes.
So now I can switch on either the brightest LED's on the headlights, or the Fog Lamp LED's, or turn them all off.
Thank you SteveDask and SparkieSRT6.
