Old Jan 30, 2015 | 07:09 AM
ala_xfire
Default Re: Water pump failing?
Originally Posted by waldig
THe bolts are similar heads and different lengths with one near the bottom thats a bit hidden.. Use a sheet of cardboard to hold the bolts so you have the locations identified. I just pierce the cardboard and store the bolts, you could also trace the gasket on the cardboard to make it really clear later,,,,, short term memory being what it is. Enjoy, Wdy
I just put the bolts into the new pump one at a time as I remove them.
Then when the old pump is off, I transfer them to it from the new one.
Put the new pump in place and once again transfer from old to new.
