Old Jan 31, 2015 | 03:01 AM
americanretrodave's Avatar
americanretrodave
Default Re: Car Dies After Sticky Ignition Key Mod
Originally Posted by eatmycrackers
The Key ring is plugged in on the back side and it doesn't look like it came out from the ring side.
The key appears to be fine
What happens if I do it more than 20 times? What is the self destruct?
"After 3 failed attempts to start you will have to unhook battery for 10-15 min. Before you can try again, you can only do that 10 times before the car ecu becomes unusable 30 no start self destruct."
The above is what I've been told. I'd try the cps it's cheap and easy to replace, if that doesn't work, I would guess the skreem, but I doubt that is it.
Dave
