Old Feb 2, 2015 | 02:31 PM
amx1397
Default Re: Wide Wheels and Tires!!
A easy to check the bolt (thread into the hub) push the bolt through a bolt hole and check inside you should have 5/8 sticking through.
also factory wheels used BALL lug bolt
aftermarket uses TAPER lug bolt
THE TAPER CANNOT BE USED IN THE BALL TYPE RIN.
AND THE BALL CAN NOT BE USED IN THE TAPER TYPE RIM
