Re: New Guy with a couple of questions
I believe the AGM is non-acid filled, so no overflow and no leakage. I bought a pair from Autozone because I had corrosion under both batteries and hoped this to be the permanent solution. Duralast H6-AGM for $170. I'm sure there are better prices but I did not want to drive all over.
A lot of owners have gone with Hankook Ventus V12 EVO tires. Do some searches and you'll find you can go larger than stock if desired. This is a very good summer tire, with uni-directional tread (no side to side rotation possible). I replaced my roadster rears with 10mm wider and the SRT6 rears with 20mm wider. Kept the fronts stock.
