Old Jun 8, 2006 | 09:19 PM
Aero Blue's Avatar
Aero Blue
Lightbulb Re: Detailed the Crossfire once again!
Ok, here's the deal with Klasse SG...ITS VERY EASY TO REMOVE, JUST LIKE AIO. I found a great tip on applying both of the "twins" and its this, dampen the applicator you've using (I use a 100% cotton pad thats square, but have just gotten a microfiber pads) Make sure you wring it out so its only slightly damp. Then apply a small amount to the applicator pad (I use a spray bottle to make sure I use the least amount, but as long as its about a 2" line, your alright). That amount along will be enough to do 1/2 the hood and from there you can you use even less because you'll always have "some" on the pad. It may look like your not applying it to the car but trust me, thats the way Klasse SG is, plain and simple. Klasse SG gives the paint clarity or "pop" and really responds to its second coat applied 8-12 hrs later. I was absolutely blown away when I did this for the first time, I was completely hooked. I recently bought a 33 oz bottle of Klasse SG for $30.00 and that was including S/H, so needless to say I'm sticking with it, no doubt about it. Now that I've found a product thats so easy to apply, its easy to keep my car looking its best everyday.
Another little tip I read about over on www.autopia.com was to mix in some Klasse SG with your quick detailer. I did this with my Griots Spray Wax, adding some SG to it for an even better Spray Wax. So whether you add it with spray wax or a quality QD, this product is simply amazing!
