I have the following items for sale, they all come from the same crossfire so if I understand correctly if you replace all of them you won't have to re-program anything.
- Ignition Switch and Lock Cylinder Assembly with Transponder Ring
- Key (the remote case is in rough shape but the key and electronics still work)
- Driver's Door Lock Cylinder
- SKREEM Module
- PCM Powertrain Control Module
- BCM Body Control Module
- TCM Transmission Control Module
- RCM Relay Control Module (This one was working but I opened it anyways and reconditioned the solder joints to make sure they are good)
I'd Like to sell the Ignition Switch Assembly, Key, Door lock cylinder, SKREEM, and PCM as a package. The others I can sell individually.
Go
here for pictures.
Send me a private message with questions offers. Thanks.
