Old Feb 6, 2015 | 04:27 PM
americanretrodave's Avatar
americanretrodave
Default Re: Key/fob/transponder question
Originally Posted by Travish
From what I understand from reading is that the Transponder "chip" in the fob must be the "original" or ordered for the car so it has the correct id for THAT car but the lock/unlock circuit board just has to be programmed by pushing buttons and turning on key. Is this correct?
Thanks
Travis
Travis,
I believe you are on the right tract, the transponder 'chip' has the code burnt into it, it can't be re-programed and it's only for your car's serial number. A virgin chip can be programed for you car with the right equipment but I believe that would have to be done by a Mercedes dealership. I'm not sure about the door locks, it would seem to me that they would be separate. Your idea of permanently planting the chip next to the tumbler assembly sounds good to me, I'm not sure how 'needed' that theft determent is, heck, none of my vintage cars have it. But that chip looks like a piece of black plastic, like a plastic tab that broke off something, it would be easy to lose if not secured well. I don't know if you would want to glue it, maybe if you put in in a clear plastic container and secured it, it might work, or attach your old pod near the tumbler assembly?
Dave
