Re: Mopar Coupon 4 Oil Changes $180
Well that is the way it has been for the last year, right at the top of the fiber marker. I make that about 1/2 quart over. No sign of foaming (if crank were hitting the oil level there would be).
ps I periodically chack the level (key on, press button, when oil can appears press twice) & always says OK.
pps "The best time to check the engine oil level is about 5 minutes after a fully warmed engine is shut off, or before starting the engine after it has sat overnight."
