Re: 20 MM Eibach Pro Spacers
Did you use them on stock wheels? What spacer size did you use on the front (if any) along with the 20mm in the rear? I was going to go with 15mm in the rear and 10mm in the front, but if the 20mm would work in the rear without issue I would consider them.
