Re: What did you do to your Crossfire today?
Had an intermittant light out indicator last week on the drive back from visiting my sister.
Sure enough, the RH low beam HID wouldn't come on, and these are Moromoto's !
In the tradition of KISS, I swapped the fuses for left and right, no joy.
Sooooooo, I removed the headlight assembly ( moved water tank, CAI and all that ).
I found a corroded connector to the HID ballast and was able to remove the pin/socked from the connector and clean it up.
LET THERE BE LIGHT !!!!!!
