penderd@att.net
Thanks for the info guys 35000. mi. on the car, and the master is full. It has sat for about 1.5 mos and ran well till I needed to stop the first time and peddle had to be pumped up, and every time after that. Was hoping it would heal itself but when I pulled in the garage pressed hard on pedal and went almost to the floor. Brake pads are good and know obvious leaks. Time to get it looked at. Thanks again for the help. Don
What was the ambient air temperature? If the brakes were last done on a warm day, you might experience what you have described on a relatively cool day. I'm not saying this is definitely your problem but it could be. Which leads me to another idea, it might be a good idea to bleed the brakes in the winter, then come spring they would be right crisp.
