Old Feb 16, 2015 | 03:59 AM
Cedar11's Avatar
Cedar11
Default Replacing Ball Joints and Tie Rod Assembly
Hello all,
My car is having suspension issues (vibration) and the mechanic said I need to replace the ball joint, inner tie rod and wheel bearing on the front drivers side.
I would like to do this myself if at all possible.
The service manual mentions that the spring must be removed to replace the ball joint but looking at the schematic I'm not sure if this is necessary. Does the spring need to be removed? Also, it mentions a special tool is necessary to remove the ball joint, is this necessary as well?
I realize the inner tie rods must be replaced with the entire assembly and the service manual mentions another special tool is required to remove the outer tie rods, is this tool necessary as well?
Thanks in advance for any help.
