Old Feb 16, 2015 | 07:13 AM
ala_xfire
Default Re: About to give up....NEED HELP!!!
It does not have "lifters", it has the same functionality in each rocker arm however.
This engine is a single overhead cam ( each bank ) 3 valve per cylinder with two spark plugs each.
The valve clearance is non-adjustable, in the tip of each rocker at the valve end is the hydraulic compensator, the other end is a roller on the cam :
