Old Feb 16, 2015 | 12:32 PM
DTMenace's Avatar
DTMenace
Default Re: Windshield Top Trim on ebay
Originally Posted by Toolman
Just saw this ebay listing and thought it was worth sharing. It's a windshield top trim for $75 including shipping. The paint looks good without chips, but many minor scratches. It appears that three of the five clips were glued back on. The rubber is peeled off the ends, but that should be easy to put back on with some trim adhesive.
If you look at the underside picture it seems to me that the clip second from right to left is glued very slightly out of position which could cause a mounting problem. I could be wrong about that. If not, it could be removed and glued back on correct positioned.
Chrysler Crossfire SRT6 Side Trim Panel Molding Windscreen Top 1936700087 | eBay
Toolman
The top windshield surround is for a Roadster, since it does not have the rubber trim on the reverse side and the part number ends with 187. This part rests on the rubber that exists on the top of the windshield, so there is no need for the rubber strip.
The Coupe top trim has the rubber strip and that part number ends with 087. The rubber rests on the metal trim of the roof. A little glue will resolve the rubber issues.
A rubber strip can be added to the Roadster molding, if used on the coupe.
Just a little of trivia knowledge.....
Dennis
DTMenace
