Re: My latest mod - Flashing Brake Lights
Removal of the trim panels is easy. Three screws & a trim removal tool or screw driver. Reference the shop manual available on this site. (I don't know how to post the pages from the shop manual) Go to Contents 23 Body then 23-48 & 23-49. Page 2903 & 2904. Be careful when installing the upper panel that the pins are clear of the flasher unit. I didn't have any problems with broken pins on the panel. The black wire with the blue stripe is positive & the brown wire is ground. A whole set of trim tools are available at Harbor Fright for $8.
5 Piece Auto Trim and Molding Tool Set
Picture is before I tucked in the wiring. Removing the plug to the brake light is by sliding a screwdriver under it & lifting up. There is a pin there but you don't have to squeeze any detent to get it to release.
