Re: My latest mod - Flashing Brake Lights
Removing the panels takes less then 2 minutes & you have plenty of room to mount the flasher module. Splicing into the wires in the fuse box is not that easy. If you are unable to remove the panels then you probably shouldn't be doing this modification. I have had my panels off several times & have not damaged any mounting clips or plastic lugs. As always check the alignment before final attachment.
