Re: Air Filter Questions
Would it help your decision if you knew that your extended warranty is probably worthless. I submit that Chrysler will be of no help if you have any problems; just my $.02.
I personally like the K.&N. oiled filters on my aftermarket dual CAI system and I use pre-filter socks over them for extended service life(you can take your socks off, if or when you go to the drag strip). When I had the stock intake system, I used a set of K.&N. paper drop in filters; easy peasy. I'm sure there are threads debating the different type of filters if you wanted to search the forum here.
I see that this is your first post on our forum; welcome.
