Old Mar 1, 2015 | 10:21 PM
KDW4Him's Avatar
KDW4Him
Default Re: Tramlining problem
Originally Posted by Oconnom
Apologies for raising this thread again, but I really need to get to the bottom of this as I feel my issue could be dangerous.
Ever since I've had my Crossfire, I noticed it has a tendency to 'tramline' (tendency to follow the ruts or worn part of a road and pulls the car to follow the surface) quite badly, on motorways and small roads, sometimes while travelling very slowly !
The technical dept. at Michelin (UK) said that sidewall stiffness has a major effect on this issue and suggested Pilot Sport 3s had a relatively supple side wall but couldn't confirm whether they would help my situation. When I spoke to my local suspension steering specialist, without a pause he suggested that if my geometry was OK, it was the tyres. Someone suggested on this forum - the Crossfire has a short wheel-base and wide tyres, the tramlining comes with the territory., but it seems some owners do not suffer from it or the effect is mild.
I posted on the UK Facebook group and out of 10 responses, 9 said they suffered from it !
I've come to the conclusion that all Crossfires suffer, the intensity/degree of tramlining is down to the particular tyre brand/model ?
Also, I guess different drivers have different sensitivities to the tramlining, maybe I'm on the sensitive side, but sometimes, it gives me the ******* !
Anyone recommend at tyre that has minimal or no tramlining tendencies ?
Thanks in advance
Mick
I have had the issue after an "alignment", seems the first dealer didn't know much about toe and proper settings but only was the reading close enough to correct. Took the car to a second dealer explaining the trouble from the first and they set about to make the car spot on and the tramlining went away with the tires I have.
