JesseJamessrt6
I finally got the suspension to the right height front and back. I ended up with 4 dots on the rear and 5 dots on the front and although it is not as low as I would like it the rubbing is mostly gone even with aggresive driving.
So to sum it up;
Front-
TSW Max 19"X8.5" et 43mm with 12mm hubcentric spacers for an effective 31mm offset, wrapped in 245/35ZR19. The OEM springs were cut 7/8 of a coil and 1" off the shock bumper and 5 dot spring pads.
Rear-
TSW Max 20"X10.5" et 40mm offset with 15mm hubcentric spacers for an effective 25mm offset, wrapped in 285/30ZR20. The OEM springs had 1 full coil cut off and 1" off the shock bumper with 4 dot spring pads. MikeR adjustable camber arms and sway bar links with modification to the body seam to allow increased upward travel of the sway bar.
I still hear a little creaking from the back that was not there before the suspension modifications that I am still trying to
Hey sorry, I know this is an old thread but jessejames, in the first page you said you got 20x10 for the rear and in the second and third you said you got 20x10.5. Which ones did you actually get?
