Old Mar 6, 2015 | 01:06 PM
onehundred80
Default Re: N/A Spoiler Removal Guide
As usual, another awesome little tidbit to help us XF lovers tear into our car's innards. Good points if you want to re-enter the area down the road! I was just looking at one of those modules to flash your high mounted brake light and by golly, this gets you right into that area. Thanks again rekcah!
I am going to put in one of these flashers and to put it in you have to remove al the panels on the hatch. I intend to fit connectors on the OEM wires and the flasher. I will extend the wires down inside the panels to the bottom, that way if I ever have to R&R the flasher I will not have to remove all the panels. Also the flasher is stickied to the hatch, if it came loose it might rattle, if I stuck it on the inside of the hatch on the inside of the face with license plate lights, it could not fall any farther and would be on a horizontal face putting little stress on the glue. These sticky pads tend to creep in the heat and slower in the cold.
