Old Mar 6, 2015 | 02:05 PM
GraphiteGhost
Default Re: Light bulb replacement in the A/C Heater Control panel / Unit
Originally Posted by RED DOG
GOOD FIND! I just need to confirm that our bulb is 3mm. I'm thinking it is a bit larger. I see that seller has caps for larger bulb too. Just need to be sure I order the correct size.
EDIT: Checking the specifications for our bulb, it is 5mm diameter . . . I bought these:
Green 4 7mm GM GMC Pontiac Buick Chevy Cluster Bulb Caps Covers 10 Qty | eBay
I also have 11 bulbs coming so will have a stock of replacement bulbs available for any forum member in need!
AS USUAL Dog/George, you's DA MAN'S! On another note, I would love a donation of one of the faulty A/C controls. I want to try to fault isolate the internals so that maybe people with these quirky controls can SQUEEZE more life out of the bad design that flooded our cars. Mine still burps (it was replaced under warranty and they would not let me have the old one) but when it does (hot when cold and/or cold when hot) I just turn the fan **** off, let it sit a couple, and turn it back on. This usually restores it, only once did I have to do it twice to 'reset' the dang thing. So, anyone have one of these they want to donate? No guarantees and if you want it back way down the road, I will gladly send it back (might be a little different than when sent as I have to 'take it all apart'.
