amx1397
yes on the charger the internal parts will not inter change and the charger housing nose mount it different. if I remember ,,,it was a year ago that i did the charger stuff,, you can put the Challenger rear in , but have to change the mounting bolt placement ,,hubs brakes and axles. i am trying to make so there is little to no extra work for the swap.
if you have found something that we missed please let me know we are all in the learn mode. jim
When I was looking at the differnt charger rearends, the rearend from the 06 with the 2.7 or 3.5 looked identical, the 10 and newer is differnt but in 06 they made 3 differnt sizes of rearends in 06.
Like the one I posted pics earlier one is upside down, but the casing between the 06 3.5 (I think it is the 3.5 not the 2.7) compared to the XFIRE looks 100% identical cover, mounting and how shafts mounts, just different oil drain and fill holes. probably have different spline axles, trying to research. But the 06 charger has 4 or 5 different ratios including 3.90, 3.64 and a 2.82.
There are several different.
Take a quick look 06 charger 3.5l and tell me if that looks like the one u already looked at and ruled out.
