Old Mar 8, 2015 | 10:10 PM
Padgett's Avatar
Padgett
Default Re: Intermittent Clutch Issue
If the level is dropping I'd look for fluid at the slave or at the clutch rod opening under the dash. If not dropping it is most likely the master cyl piston seal not holding pressure all of the time.
Just probabilities to check, not certainties.
