Old Mar 9, 2015 | 12:13 AM
4drturbo's Avatar
4drturbo
Default Re: SRT-6 Antifreeze Change Procedure
Originally Posted by mach2plus
we can still remove that small amount of engine block antifreeze by draining our systems as best possible, and then refilling the system with straight distilled water and then running our cars until the themostat opens, at which time they will all mix together. Then, just drain it again and add your mixture to yield whatever coolant mix you desire. (50/50 in my case. But remember not to keep just distilled water in your system for any long period of time because you will suffer impeller erosion, which is prevented by the lubricants in antifreeze.
But, to get back to my original premise, given what I've been reading, I believe that when a lot of SRT owners change their cooling fluid they are only draining the engine cooling side (8.1 quarts in my case) and not the intercooler cooling side, unless they drop or remove the charge cooler radiator and drain it as part of their procedure.
My long winded 2-cents. best regards -- bob
So this is how we should do it. Drain out the coolant out of the radiator. Then fill with just distilled water. Drive the car and get it to operating temps, then drain it again. Then fill with 50-50 mix with Zerex G-05 5yr/100k coolant.
Is there a how-to on draining the coolant from the car?
